Hello people, I need some help with a new issue, the thing is that I would like to change the role model for all my plates in just one time, but I don't know how to get it.
Edit: I found the same problem trying to change the coating in all of my plates.
Thanks in advance for the support.
Antonio.
Solved by Emanuel.Nestor. Go to Solution.
Solved by lk. Go to Solution.
Use "Selection filter" in Advance Steel Tool Palette and just select all plates, then use properties for all selected objects.
The variant to select all plates and then to use Advance Properties to set the Model role - works with one condition: all the selected plates must be outside of a joint connection.
If the Model Role of one plate is controlled by a joint, then the combo box for all selected plates will be grey and inactive.
When create manually a plate, the Model role is set to "None"
You could use the Search Filter function to select all plates with the specific Model Role "None"
Best regards,
Emy
