I can select members within an API, but I need to PAN or ZOOM the drawing to allow complete selections. I can use the sendcommand but that executes when my API exits. I can shutdown my API to allow the PAN to execute. I can use the CommandEndedReactor to restart my original API, but I don't know how to differentiate between a original API start versus an API return. Ideally I could pass an argument for a return. Ideas?
Solved by ChristianBlei. Go to Solution.
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.Command("_.zoom")
HTH,
Thanks Christian, I got it to work the hard way but it required saving and recalling data that is unnecessary if your idea works. So far everything you've suggested for me has worked great so I will switch to your idea.
