I have 30 mm circular place in my model to which I have to give a 45° bevel cut at the periphery of the plate.
I have attached 2 snaps for better understanding.
Solved by Rob_Merriman. Go to Solution.
If you look at this thread the steps are in there from @Sebastian_Eiche and @mick-CNF
https://forums.autodesk.com/t5/advance-steel-forum/groove-pipe-end/td-p/9316575
You need to model a polygon contour, set the boundaries to a couple of mm then use polar array to achieve what you want
Rob Merriman, AEC Technical Lead, Graitec
The solution is about the contour cut and polar array which also works on plates.
