I have 30 mm circular place in my model to which I have to give a 45° bevel cut at the periphery of the plate.
I have attached 2 snaps for better understanding.
Solved by Rob_Merriman. Go to Solution.
If you look at this thread the steps are in there from @Sebastian_Eiche and @mick-CNF
https://forums.autodesk.com/t5/advance-steel-forum/groove-pipe-end/td-p/9316575
You need to model a polygon contour, set the boundaries to a couple of mm then use polar array to achieve what you want
Rob Merriman, AEC Technical Lead, Graitec
@Rob_Merriman Thanks a lot!
That is not solution.
He is asking for plate, not for pipe.
The solution is about the contour cut and polar array which also works on plates.
