is ther a quike way to find the master joint
just doulbe cliked heeps of joint boxes looking for the master is ther a way to select one joint max and fins its master
or are u supost to keep "upgrade to master"
is ther any negitive efects to chaginf master about ofen
Solved by ZHUKOV_ING. Go to Solution.
You dont need master joint any more, go in slave join and UPDATE TO MASTER, all the changes you made it will be updated in all joints, next time you can select any joint and UPDATE TO MASTER.
