Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
how to find master joint
3 REPLIES 3
alickomay
2710 Views, 3 Replies
alickomay
is ther a quike way to find the master joint
just doulbe cliked heeps of joint boxes looking for the master  is ther a way to select one joint max and fins its master
or are u supost to keep "upgrade to master"
is ther any negitive efects to chaginf master about ofen
3 REPLIES 3
wtheron
in reply to: alickomay
wtheron
You can use the search filter to locate the master joint. You will need to know the name if the joint.
ZHUKOV_ING
ZHUKOV_ING
You dont need master joint any more, go in slave join and UPDATE TO MASTER, all the changes you made it will be updated in all joints, next time you can select any joint and UPDATE TO MASTER.
garretV8RZ4
in reply to: ZHUKOV_ING
garretV8RZ4
Problem with this solution is if you've named your joint then you lose the name.
