Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
How to do parametric customised connection for girder (Beam member)?
2 REPLIES 2
nagesh.l
328 Views, 2 Replies
I am facing the problem in changing the customized connection for 
beam members (Tapered beams) because of parametric issue.
I have created one customized connection for tapered beams and I want to use that same customized connection for joining different size tapered beams with parametric.
Regards
Labels (3)
2 REPLIES 2
Sebastian_Eiche
in reply to: nagesh.l
Why do you use a custom connection? In the last time I got the feeling, to much users just custom connections instead of looking for a conenction in the conn
There's one for this situation in the connection vault --Splice joint
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian_Eiche
double post
Sebastian Eiche
