I am facing the problem in changing the customized connection for
beam members (Tapered beams) because of parametric issue.
I have created one customized connection for tapered beams and I want to use that same customized connection for joining different size tapered beams with parametric.
Regards
Why do you use a custom connection? In the last time I got the feeling, to much users just custom connections instead of looking for a conenction in the conn
There's one for this situation in the connection vault --Splice joint
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
double post
Sebastian Eiche
