Hi all,
I am trying to delete some label names that I have created that I no longer need. I'm still relatively new to Advance Steel and have been adding some new labels with appropriate criteria to suit my workflow. This has mostly been successful, but I now have a few old label names that I created when I was faffing about trying to figure things out. For example, see screenshot below. I no longer want "Copy of Empty Attached beam" to appear in the list of available preset label types. It's not doing any harm to be fair. It would just be nice to condense the list a little.
Thank you in advance. I hope there's a solution!
I'm still only a few jobs in with my advance steel career.
Solved by Sebastian_Eiche. Go to Solution.
You could do this in the management tools in the Table Editor.
Open the Databases and filter for "manual":
Right Mouse button click on the field in front of the key and then choose delete:
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Many thanks. I felt for sure it would be in the management tools somewhere. Thank you for showing me the way.
