Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
how to define a specific scale for sections
5 REPLIES 5
eyal.ch
302 Views, 5 Replies
eyal.ch
Hi All,
I'm using the Drawing process for creating the drawings from my model.
when I make sections it creates them by default as 1:10 how can I change this default to 1:5?
also, is there a way to create sections after creating the drawings with the 1:5 scale as default instead of the 1:10?
thank you
Hi All,
thank you
5 REPLIES 5
Jonathan3891
in reply to: eyal.ch
Jonathan3891
Are you creating sections using the "Create Cut View" tool?
Jonathan Norton
Blog | Linkedin
Jonathan Norton
Blog | Linkedin
eyal.ch
in reply to: Jonathan3891
eyal.ch
Exactly, I'm using the Create Cut Tool and I get a 1:10 scale, how can I change it to a 1:5 scale?
Jonathan3891
Jonathan3891
After activating the tool, press "S" for settings.
The top drop down is the scale.
I'm looking into the default scale and will get back to you if I can find where to set it.
Jonathan Norton
Blog | Linkedin
Jonathan Norton
Blog | Linkedin
Jonathan3891
Jonathan3891
Looks like you cannot change the default scale.
This is directly from the help documentation:
 "The default scale is an intelligent setting that uses the scale of the view selected for the manual cut view. Using the default scale allows you to create manual cut views (that use the scale of the main view) faster, without the need to manually match them afterwards"
Jonathan Norton
Blog | Linkedin
Jonathan Norton
Blog | Linkedin
Sebastian_Eiche
Sebastian_Eiche
the default means: the scale which is set in the detail style is used. So for such often used commands it could be done with a specific detail style:
And if you use this often exact like this, a button with this command is very powerfull. Therefore, just select the dewtail style one time and have a look in the command line which key is used:
Now you could create a button with the command: _AstM4DetManualCut;R;22006;
Now you could easy clcik on the button with the correct detailstyle and correct scale.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
