Message 1 of 16
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I need to create a new profile section, how do I do this? Thanks.
Hello Marceu Heinzmann,
You can use different methods depending on what you want / what you need.
1. If you want a general section (a shape that is not standard): you can create new profile section by "User section" functionality.
You create the section shape that you want in a drawing and then use the command to add it to database.
You can find detailed information about creating a "User section" in the Advance Steel User guide, that can be found in the link bellow (chapter "Special parts, Special sections" --> "User sections", pages 102-107 for English User guide)
2. If you want to add a new section to an existing profile (for example a new Flat section), you will add it directly in the profile database.
Follow the bellow steps to add it using Management Tools. You can use also a dedicated database software, like Microsoft Access.
Best regards,
Emy
I can add to this in that Owner Text column is very important to change to a different value from DSC. When a new version 2016 is released it will be neccesary to merge databases in order to not lose these user defined sections when migrating to a new release. If the Onwer text remains as DSC the merge is not completed correctly as it presumes that this section has been updated by Autodesk.
Thanks for the response, but when I create a new profile to a existing profile, should I insert all properties like "weight per meter" or "sectional area" or the software calculate automatic? Thank you.
You can let these columns not filled and AS will calculate some of them (it will not calculate for example Iz, Iy ...).
However, if you can it is recommended to fill these data, because it is possible to have differences between calculated values and catalog values.
Best regards,
Emy
Ok. Thanks.
Hi Emanuel,
I can follow your explanations until step 5 (ProfileMasterTable) but couldn’t find the column corresponding with installation language.
Can you explain to me how to find that column?
Fyi, I am using Advance Steel 2021 (Student Version).
In the new versions of Advance steel there are no country columns in the DB tables.
they changed to separated folders and installs for each country/group of countries
John Bennett
Hi John,
Thank you for info.
So, how about steps to create a new section profile if there is no “language column”??
you don't need the language column. This was only needed in the past, if you just fill the column which are there, it is working.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Hi @rimutaka
Thank you for your question.
As mentioned above, the Language columns are not used anymore, starting with AS 2018 version.
Instead, you use directly the column "RunName". Please see attached image for reference.
Hope it helps 🙂
Emy
Hi, is it possible to create a user section for this type of profile? please see attached.
every time i tried to generate from user section i always end up to an error of too many contours.
you need to create each section, and after this you could combine them:
Sebastian Eiche
can you please help me to this also, is there any chance we can define the single part after combining all the section. please see attached.
what do you mean? The note "not defined" means you don't use the numbering command of Advance Steel until now.
Just use the numebring dialog and the element will get a number
Sebastian Eiche
