Hi All,
Does anyone know how to change the unit's precision to be with 1 digit after the dot?
As you can see, the sum of 48+80+48=176mm gives a total of 175mm, I want it to give 1 digit after the number, and if the digit is zero, not show it ( like a trail in AutoCAD).
thank you
Solved by Sebastian_Eiche. Go to Solution.
change the dimension style to show more character.
Instead of 48, it's maybe 47,6
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Hello @Sebastian_Eiche
I already changed the dimension style, but it gives 2 digits after the dot, I need only 1.
How can I do it?
thank you
this is a setting of the primary units:
Sebastian Eiche
