Advance Steel 2023 - Connection Vault items not visible in camera
takarun87
Observer
Observer
takarun87
Observer
Observer
I used a connection vault to create a handrail model for a walkway, and I used a camera to make the detail sketch. I was surprised to see that everything had appear except for the connection vault items. How can this issue be resolved?
[ The subject line of this post has been edited for clarity by @handjonathan Original: using camera]
pendean
Community Legend
Community Legend
@takarun87 Which software are you using? You posted in a forum that has no specific software tied to it, so no one is going to answer your query.
takarun87
Observer
Observer
 Advance steel 2023
pendean
Community Legend
Community Legend
@takarun87 wrote:
 Advance steel 2023
Someone moved your post to the correct forum now. Hope you get answers.
AleckGiles
The railing macro is not in Connection Vault so I am a bit confused by your question. when using a camera you can specify which drawing style it should use for the view. Try using different drawing styles such as 3D View All No Labels to get everything.  Some styles (such as floor plans) deliberately leave out railings.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
handjonathan
Hi @takarun87
Thanks a lot for posting your question to the forums!   Has the solution suggested by @AleckGiles helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
