Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
How to add Shackles and Wire Rope Clips?
1 REPLY 1
rodrigo1434
410 Views, 1 Reply
Hi fellows,
How can I add shackles and wire rope clips into the database and get it numbered and considered afterwards in the bill of materials ?
(I tried adding 3D Solid for representation but I rather use the smart way along the BIM database)
Thanks!
1 REPLY 1
johnjmbennett
in reply to: rodrigo1434
Take the solids of the shackles, put them in separate plain autocad files, with a part ref as the file name.
tyen insert them into the model as special parts,  once in the model they are seen as AS elements.
make sure the part file has the parts insert point you wish at the 0,0,0.
search AKN for advance steel special parts.
John Bennett
