Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
How to add a note to the detail?
10 REPLIES 10
Message 1 of 11
robertnowak
1494 Views, 10 Replies
I would like to add a note/text to the particulat detail - how can I do it? I tried to cheat a bit and give a label to one of the elements on the drawing, replace it with my own text and turn off the lines, but usually it dissapears after update or relocate so its useless. How then add a note that will be a part of a detail?
10 REPLIES 10
Message 2 of 11
vuk.vukanic
in reply to: robertnowak
Is there a reason Multiline Text would be inadequate?
Easy things are not worth the effort
http://www.teamcad.rs
Message 3 of 11
robertnowak
in reply to: vuk.vukanic
not exactly, because in case of moving that detail (it happens after updating the drawing or when I just want to change its position) there is a high chance that I forget to select that text or the detail will move automatically leaving the text. Moreover when I use Multiline text i can't check what detail it belongs to.
Message 4 of 11
wslomiany
In your drawing style DETAIL TITLE, you can choose the token OTHERS which will show a user entered notation from the camera description.
You can even have the camera node locations labeled in your G/A drawings as well.BEAM TO COLUMN.PNG
Message 5 of 11
robertnowak
in reply to: wslomiany
wslomiany, thanks for your answer.
I know that option and it's not what I was looking for. I would like to add an extra note to the detail despite it's description.
Look at the screenshot below and yellow text:
This is just an example not the real situation, but I think you get the point. I made that yellow text with Autocad tool but in cases i described in previous post, it is quite inconvenient solution.
Best regards
Robert
Message 6 of 11
deand
Did yo find a solution for this? is there a way to attached the multiline text to  a view?
Message 7 of 11
A workaround is to add a label to a detail but change the text of that label to say what you need said.  It would be attached to the detail and move with it.  Not the most elegant solution, but should work.
Message 8 of 11
I do it in 3 ways depending on the nature of the note:
   1. General note (identical on multiple sheets): XREF-ed on prototypes
   2. Dependent on the assembly (as in the example above regarding the weld thickness): User attributte token in Drawing Style Detail title for main part
   3. When creating GA drawings (using Camera): Labeling Strategy that includes the appropriate User Attribute
Message 9 of 11
robertnowak
@vuk.vukanic, I'm doing a similar workaround.  I reserved one of "user attributes" token for that kind of notes. It would be a perfect solution if it was possible to set 2 labels to one element. Unfortunately it's not, so I have to add these "user attribute" labels manually in the drawing. At least it doesn't disappear after update 🙂
Best Regards
Robert
Message 10 of 11
vuk.vukanic
I don't do any manual labeling in the drawings, so I might be able to help if you elaborate on why would allowing 2 labels per object help.
Message 11 of 11
You could add a very small object like a special part and use an extra label strategy for this, by using the free remark entry an then add a special role in your detail style.
Another idea: a weld from type dummy without leaderline the additional information
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
