Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
How do i create a bolted spacer beam?
1 REPLY 1
drawingsJKKBU
899 Views, 1 Reply
What steps should i take to build a spacer beam?
i and able to put a tube spacer onto the beam web but I'm struggling with creating the holes along the web and putting the bolts through.
the photos attached are similar to what i want to create
1 REPLY 1
CHRIS_ASDL
in reply to: drawingsJKKBU
Use the Rectangular two point feature from the Objects ribbon. Make sure that its set to bolts Capture -2.PNG
 Use the Advance properties to space the bolts accordingly and then insert your spacers and the same spacing.
Hope that helps!
Kind Regards
Chris
Technology Administrators
