I has created connection for the model, and then, i has been copy this connection to other frame, so, how can i re change all this connection
Thanks you
Thanks you
Solved by TomislavGolubovic. Go to Solution.
Did you copy just the connection, or copy and group the connection?
Thanks you, i have to copy connection by tool "CREATE BY TEMPLATE" in a frame, and then i copy that frame to many frame.
right now i has been update for one connection, i want update all connection like that
For future, if you're going to copy one joint and have a parent/child relationship with the joints, you might want to use the button in the attached screenshot
Thanks Tomislav Golubovic,
i'll be check again with your method, thanks you so much
For your current situation, I think you are looking for _AstM4TransferParams command.
This is available from the Joint Utilities Ribbon on Extended modelling tab.
