How can I change the position of the element in the drawing?
eyal.ch
eyal.ch
Hi Everyone,
Somehow 4-5 of my assemblies appears from top view on the drawing and not from the side as usual,
the drawing below is the main drawing,
if I make section to the side section, it gives something weird:
Why did it happened? and how to fix it?
it's very urgent for me, thank you all
j.hamelin
Don't know why it happen by here's the workaround.
In model, set UCS as desired, select the main part of the assembly then click on [Tools] Define assembly detailling direction. Of course you will need to Force Update after this.
Hope this help!
Mechanical Design Drafter
If this information was helpful, please use the Accept as Solution function, this make it easier for other users.
eyal.ch
Hi @j.hamelin
thank you,
It works great!
