Does anyone knows how can I drill some holes into a CHS pipe? It should be like in photo attached. Thanks!
Set the UCS on the required face, then use the hole command as per the below screencast. You may need to add to sets of holes both sides.
https://knowledge.autodesk.com/community/screencast/936b9166-11da-4670-901d-2781d38df278
Unfortunately, the screenshot I have uploaded is not very clear. I have managed to make some holes on one side of the pipe, but I need also another 2 sets of holes on 120 and 240 degree. Please see atached a section view.
