Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Holes in CHS beam
4 REPLIES 4
596 Views, 4 Replies
Holes in CHS beam
Does anyone knows how can I drill some holes into a CHS pipe? It should be like in photo attached. Thanks!
4 REPLIES 4
múinteoir
Set the UCS on the required face, then use the hole command as per the below screencast. You may need to add to sets of holes both sides.
https://knowledge.autodesk.com/community/screencast/936b9166-11da-4670-901d-2781d38df278
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
in reply to: múinteoir
Unfortunately, the screenshot I have uploaded is not very clear. I have managed to make some holes on one side of the pipe, but I need also another 2 sets of holes on 120 and 240 degree. Please see atached a section view.
I have succeded finally to copy&rotate the holes in order to have those angles.
múinteoir
Thats the best way, add a single set, then rotate
