I have a folded plate assembly. I have tried several attempts to re-orient the detail coordinate system without any luck.
This is a single part detail. My wish is to have the front view rotated 45 degrees ccw in the detail drawing. I have tried to set the detail coordinate system, but since this is a single part, I can't set main part. It is defaulting to one of the sloped surfaces.
I have attached a model and detail drawing. Any help is greatly appreciated.
Thanks in advance.
Solved by bigcarl5000kg. Go to Solution.
the orientation is driven by main plate of the bend plate (see the blue marked symbol):
Use this command to change the main plate:
_AstorFoldedPlateSetMain
Example:
Result in the drawing:
HTH
Never realized that button existed/what it was for until you pointed it out.
Thank you very much!
