Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Gusset Plate Member Connection
2 REPLIES 2
372 Views, 2 Replies
When connecting gusset plate to beam and column, using "Gusset plate to column and base plate", we want to offset plat from column web 1/2". However the clip angle also moves back 1/2" with the gusset plate. Is there a way to to do this without erasing the intelligent connection and manually moving the clip back to web? See picture belowGusset Plate.jpg
2 REPLIES 2
Sebastian_Eiche
What you definitely do is to add a 'cut on object' command and then you could combine it to one customer joint. I'm not in the office anymore, so maybe it's also possible in the connection directly but I could not test
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
in reply to: Sebastian_Eiche
Sebastian,
Thanks! That is a viable work around. Allows me to keep intelligent connection.
Technology Administrators
