Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Gray box around detail view when clicking "median line color". how to erase?
2 REPLIES 2
RonBuckingham
649 Views, 2 Replies
RonBuckingham
Relatively new user here.
I am in a drawing and right click "advance properties" on a view.  The dialog box comes up, I select "axes" then check next to "median line color".  A gray box appears around the view, and I can not get rid of it by unchecking "median line color".  If I try to select and erase it, the entire view is deleted.  what is that gray box? How do I get rid of it?
thanks
Ron
thanks
Ron
2 REPLIES 2
AntDrt
in reply to: RonBuckingham
AntDrt
Hello !
gray boxes means you have made modifications in drawing you require an update of the view.
for your example, add anew line in drawing require an update to "generate" this line.
in general, grey boxes are showed to say to us "you made mofication, upadte the view to see them"
see screencast below:
Antoine
AMG Fechoz
Serrurerie & Equipement Scénographique
www.amg-fechoz.com
Hello !
Antoine
AMG Fechoz
www.amg-fechoz.com
RonBuckingham
Thank you AntDrt!
Ron
Thank you AntDrt!
Ron
