Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
GA Drawings
4 REPLIES 4
Bmcdonald.kwwllc
381 Views, 4 Replies
GA Drawings
Bmcdonald.kwwllc
I am to the point I can number and create a parts sheet. My issue is I need to figure out how to get my GA drawings with part numbers attached. I am using cameras, so when I go to the Doc. Manager the drawing only shows 3D Views with no part numbers. Help!
GA Drawings
4 REPLIES 4
Sebastian_Eiche
you had to select a detail which is using a labeling for the parts. If you use "w-label" style it means: with labeling, if you use a "w/o label" style, it means: without labeling
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
Bmcdonald.kwwllc
Thanks!
Thanks!
Bmcdonald.kwwllc
It is adding in the description ex. (HSS 2X2X1/8) instead of just the part numbers pointing to each part!
Sebastian_Eiche
That's because the detail style is set like this.
To change this it's recommend to work with advance steel for a while because you had to change the detail style and the label strategy for this parts. If you want this, you will find some help here and some videos on YouTube.
Maybe it's better you create a detail without labels and make them manual? Therefore the manual label strategy had to be changed. You could found some information to this in the Advance Steel help or here in many forum threads. It's much easier than changing the detail style
Sebastian Eiche
Sebastian Eiche
