I'm trying to model a fascia which is folded on multiple sides. It doesn't look right and it says it can't be unfolded properly after applying check. What did I do wrong? I've attached the DWG file in this post. Please help.
Advance Steel is no really 3D CAD and not at all for bent sheets .... in my opinion 2,5D only.
If you change the bending radius to 3mm (R=0 -> kink, no bend), it will be better, but still unusable. There is simply a lack of tools for sheet metal processing (real bends, cut offs, ... what you know from real 3D CAD)
The first question is what do you expect to happen at those corners in real life? The edges to be folded together should match in length. If they do not then there should be a bend relief in the longer edge where the shorter edge ends. You could also clip off the little "tail" that you don't want.
You can model your own bend relief if you change the Display Type of the plate to Unfolded then add contour cuts to the relevant locations. When you change back to Standard Display Type the bend relief will be folded into the model.
Aleck Giles, Structures Consultant, Graitec
