Export List to excel
vuongbui.nuce
vuongbui.nuce
when i create some list in ads i need to export to excel file. But some format cell always is text, can we custom setting in ads export format cell is Number. Thanks
engelbert_schreiner
Observer
Observer
same problem! Does anyone have a solution?
Emanuel.Nestor
Autodesk Support
Autodesk Support
Hi @vuongbui.nuce,
Thank you for posting on the Advance Steel forum.
I assume you are working with the 2025 version, right?
If yes, then indeed, there is an issue that the "Numbers" are exported from the BOM list as "Text" in Excel. The issue has already been documented and sent to the development team for investigation.
For now, one method is to use the option "Convert to Number" option inside Excel file:
Does it help?
Best regards,
Emy
Emy Nestor
engelbert_schreiner
Observer
Observer
OK, I hope the problem will be fixed soon.
bigcarl5000kg
Hi @engelbert_schreiner ,
@vuongbui.nuce
in the BOM Editor, have a look at this setting for each such cell. There are several options like in Excel.
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
vuongbui.nuce
thank you, @bigcarl5000kg @Emanuel.Nestor . it worked, but we need setup outputformat each cell, if we can setup automatic when export excel its very nice.
jan_fDXGKH
Observer
Observer
I have problem that after switching to numbers in export option it gives me 660000  instead of 0,66 , but positive is that it is not text but number. Any suggestions?
