Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Export List to excel
5 REPLIES 5
vuongbui.nuce
356 Views, 5 Replies
when i create some list in ads i need to export to excel file. But some format cell always is text, can we custom setting in ads export format cell is Number. Thanks
5 REPLIES 5
same problem! Does anyone have a solution?
Hi @vuongbui.nuce,
Thank you for posting on the Advance Steel forum.
I assume you are working with the 2025 version, right?
If yes, then indeed, there is an issue that the "Numbers" are exported from the BOM list as "Text" in Excel. The issue has already been documented and sent to the development team for investigation.
For now, one method is to use the option "Convert to Number" option inside Excel file:
Does it help?
Best regards,
Emy
Emy Nestor
OK, I hope the problem will be fixed soon.
Hi @engelbert_schreiner ,
@vuongbui.nuce
in the BOM Editor, have a look at this setting for each such cell. There are several options like in Excel.
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
thank you, @bigcarl5000kg @Emanuel.Nestor . it worked, but we need setup outputformat each cell, if we can setup automatic when export excel its very nice.
