Elgato stream deck
filip_denolf
Elgato stream deck
filip_denolf
i got the https://www.elgato.com/en/gaming/stream-deck-xl on my desk today.
does anyone know how i get the icons from advance steel in a .gif .bmp ... format.
i know when autocad uses toolbars you could find them.
Now i don't know anymore places to look...
Replies (24)
Sebastian_Eiche
Which one do you need? the pics are all stored in different dll files. I saved some of them, but the way, the most user go: take a screenshot and save it as bmp
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
filip_denolf
Some of the advance tool pallete.
But i will use your advice to take a screenshot (use magnifying glass first)
filip_denolf
thx to matrix software to find an even better solution
markhubrich
Hey filip how do you like your Elgato?
...and fix the kiss export issues.
filip_denolf
Super tool! Don’t want to miss it anymore
markhubrich
Was there any trick to getting Advance Steel to recognize any stream deck command? I can get it to work with other apps. Autocad does not respond to anything I do.
filip_denolf
An example
markhubrich
For example I put F8 on a key and nothing happens. If I click over to bluebeam and press button it toggle a menu. AutoCAD does nothing.
tekenbureel.denolf
markhubrich
Thanks for confirming. Exactly what I'm doing too. Advance Steel doesn't react though. It works great in Rhino3D and everything else. 😑
filip_denolf
Did you “enter” or put a “space” after the commando?
markhubrich
I tried both ways. It just will not interact in any way with the Acad instance. All other areas on my workstation receive some kind of proof of interaction from the buttons. Only Acad completely ignores any sign of Elgato.
tekenbureel.denolf
Did you make it default profile?
Maybe when autocad starts elgato takes an empty profile?
markhubrich
I got it now. It doesn't like AS run as admin. Even if I run the app as admin.
I didn't actually buy an Elgato. I am using my iPad with the Elgato app. I found something better though called Touch Portal. I can have 110 buttons and customized flows etc. I'll play with it for a few days and start a new post with how well it works out. So far it's pretty cool. For example I created an Ortho button based on F8 hotkey. I can have the button turn green while Ortho is active and gray when inactive. So many possibilities.
tekenbureel.denolf
i'm looking forward to read your post about it 🙂
Also got the elgato
app but like my 32 button streamdeck more
markhubrich
This has to be one of the most productive enhancements I have ever made to my workflow. This is why I love this community.
I extracted every bmp and .ico file from every dll found in C:\Program Files\Autodesk\AutoCAD 2022 including all subfolders.
There are 6902 of them total.
They are attached if anyone's interested.
tekenbureel.denolf
I am, thx!
tekenbureel.denolf
 Hi, i'm trying "touch portal" too but every text action i'm getting pasteclip command.
When i'm first click in the command line and then the "touch portal" button, then the (in this example) save command works.
it seems i'm getting the problems with "touch portal" like you have with "stream deck"
markhubrich
@tekenbureel.denolf I had the same experience with Touch Portal. It seems like it would be more customizable than Elgato so I tried it. Too bad it doesn't work. The only problem I had with Elgato was it doesn't like ACAD running in admin mode. It works fine for me now. I think my favorite function is the multiple command structure you can create.
For example..  Hide roof deck:
AstM4CommModelSelection Query name:"ROOF DECK" Run Query?1 Folder name:"" Reset Data?0
_AstM4CommSelectMarkedObjects
AstM4SwitchReprMode_
After messing around I realized that I didn't need to use a multi action, but it works so I left it.
