When checking joints bolts' resistance is zero. How may setting correct check resistance. Thanks
Solved by Dias_Antonio. Go to Solution.
We assume you
- Selected correctly the joint design and also a
- Double click in the macro that generated this joint
Select the property Joint Design in the Properties Window and select the correspondent coding (for example EuroCode)
Take a look in this article by Graitec
- Marque "Aceitar como SoluĆ§Ć£o", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de UsuƔrios Autodesk Brasil
