Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Edit tollerance plate
2 REPLIES 2
390 Views, 2 Replies
Hello everyone,
How can I change the hole tolerances?
The model has been exported from Revit to Advance Steel.
Thanks.
Labels (1)
2 REPLIES 2
Sebastian_Eiche
select an anchor, right mouse button click--> Advance joint properties.
In the dialog you will find an option to set the difference.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
in reply to: Sebastian_Eiche
Super!!!
