Hello everyone,
How can I change the hole tolerances?
The model has been exported from Revit to Advance Steel.
Thanks.
Solved by Sebastian_Eiche. Go to Solution.
select an anchor, right mouse button click--> Advance joint properties.
In the dialog you will find an option to set the difference.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
