I'm just wondering, is there anyway with a Plate, when exported to DXF, to still show the scribing of the beam attached but remove the main part name?
We have the same plate for many different Main Parts is all, so gets confusing for the manufacturing guys.
hmm in general you could change the default for the "text for attached objects contours in NC" to empty
But this will deactivate it not only for attached beams on footplates...you will have no text for example for "stiffeners on beams"
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
