Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
DXF Plates
2 REPLIES 2
SamanthaPrazza
268 Views, 2 Replies
DXF Plates
SamanthaPrazza
I'm just wondering, is there anyway with a Plate, when exported to DXF, to still show the scribing of the beam attached but remove the main part name?
We have the same plate for many different Main Parts is all, so gets confusing for the manufacturing guys.
DXF Plates
2 REPLIES 2
Sebastian_Eiche
hmm in general you could change the default for the "text for attached objects contours in NC" to empty
But this will deactivate it not only for attached beams on footplates...you will have no text for example for "stiffeners on beams"
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
abeeler
in reply to: SamanthaPrazza
abeeler
Also, you can toggle the signature on or off via NC settings.
