Can someone please help me with this?
Whenever I create my detail drawings, even if I select "Beam" for model role, the drawing always put "Bolt" in drawing title. And reference drawing does not show up too.
it looks the some of the attributes are not correct in the titleblock. Can you attach the prototype?
Dear Colleague
You need to access the ribbon "Output" and find the button "Edit prototype" and find the paper size you are working and after that click in any area of the paper and select "Edit Block"..
Double click in Bolt and verify if the attribute related to it is correct...return to the ribbon Start and access the button Project configurations to see if the word Bolt is in it...
If yes type the word you want...return to edit prototype and confirm.
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
