Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Drawing Title
2 REPLIES 2
rosskristian25
308 Views, 2 Replies
Drawing Title
Can someone please Drawing title.pnghelp me with this?
Whenever I create my detail drawings, even if I select "Beam" for model role, the drawing always put "Bolt" in drawing title. And reference drawing does not show up too.
2 REPLIES 2
múinteoir
in reply to: rosskristian25
it looks the some of the attributes are not correct in the titleblock. Can you attach the prototype?
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
Dear Colleague
You need to access the ribbon "Output" and find the button "Edit prototype" and find the paper size you are working and after that click in any area of the paper and select "Edit Block"..
Double click  in Bolt and verify if the attribute related to it is correct...return to the ribbon Start and access the button Project configurations to see if the word Bolt is in it...
If yes type the word you want...return to edit prototype and confirm.
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
