Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Drawing placement
1 REPLY 1
dusanduckinoski996
325 Views, 1 Reply
Drawing placement
Hello, when i generate the drawing it is inside of the frame but i want it to be centered not left or right, is that possible with DSM?
Second i found out that this problem is maybe caused by the hypersteelpageframe, my frame in prototypes isnt a block, it is polyline. But if i put block hypersteelpageframe to be my frame for A4, how could i make block hypersteelpageframe to be frame for my A3 when it already fits with A4? There is only one block hypersteelpageframe right?
1 REPLY 1
If you are making a new prototype it is always better to start with an existing one and modify.  I would base a new A4 prototype on an existing A4 prototype and so forth.
Each prototype file will have a block hypersteelpageframe. This will be a different sized block in each prototype for different sized layouts.
On the standard prototypes I found that the drawings would regularly overlap the edge of the layout.  If you pull the frame in from the edge a little then the drawings will fit easier.  Shown in screenshot below.
