Diagonal bracing drawing style
salvador90
salvador90
we would like to have our diagonal bracing assembly/part drawings shown and dimensioned at the angle they will be installed/fabricated with the end points of the system line as the end points of the dimensions. I know I can change the CS to get it to show at the angle it will be at but is there a way to make the angle bracing and tube bracing drawing styles to start with this automatically?
salvador90_0-1631048705180.pngthis in lieu of
salvador90_1-1631048757275.png this
acbsdesign
Hi @salvador90
This can be done if you assign detailing direction per UCS or just copy and modify an existing dwg style to be per UCS.
Add two dimension requests, one along X, one along Y.
The result would be:
Hope this helps.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
salvador90
Thank you, that helped so much. I got the view like I need it now I just need the slope triangle dimension for the main part. I don't know what I need to set it as for the triangle to show up for the system line as it was on the original example.
Also, is there a way to have the drawing clip in the direction of the main part or is it restricted to x and y? When it clips in the x direction this is what happens.
I can live with no clipping at all if it is not possible but thought I'd ask.
acbsdesign
@salvador90
For the clipping along MP - this is not possible, clipping has to be along X and Y, so clipping has to be turned off from the dwg style-Detail View Properties:
For the slope triangle-I have to work on this later,
or if someone else has it already done-please post it here.
salvador90
setting the detailing direction to ucs works with some but because I have braces in multiple directions, the other one shows up sideways. Do we have to just create the assembly drawings one portion at a time changing the ucs as needed? or is there a way to do the same for all assemblies?
acbsdesign
We have to do it for each direction separately.
sdonohoedesign
There is another method that can be used to add additional details onto drawings.  It doesn't take too long once you have got the hang of it.  A lot easier than having to change UCS view direction for every brace.
  1. Place camera(s) in model as required to show your bracings.
  2. Produce camera view and tidy up / add dimensions you need (or leave it plain and add later)
  3. Through DM use the 'explode to dwg' button.
  4. Open exploded dwg file. (keep file in default location)  Copy exploded camera view from paperspace into model space and scale to full size.
  5. Open brace drawing in AS.
  6. Xref the exploded DWG into model space.
  7. Add viewport to paperspace and zoom to your desired view.
  8. If item updates at a later date you need to update the camera view in AS, re-explode & re-scale.  This will then automatically link through and update on your brace drawing.
Example below shows this method used for a Kingspan eaves strut.  The detail in the bottom left is the standard part drawing produced by advance steel, the view at the top is taken from a camera in AS.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
