Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
drawing is not shown when created
6 REPLIES 6
eyal.ch
187 Views, 6 Replies
Hi All,
I create a drawing using a camera
when I select the camera to create the drawing:
on the document manager I see this result:
What should I do.
thank you.
6 REPLIES 6
What are the properties of the camera? Is it set to draw objects inside the camera, or did you pick the objects to draw?
Lewk_SGS
in reply to: eyal.ch
From that screenshot, it doesn't look like anything is inside of the camera's box.
Lewk_PSB is an old account that is owned by a company I no longer work for.
If this reply answers your question, please "Accept as Solution" - Thanks!
Hi @Tomislav.Golubovic
Where is the option to draw inside the camera?
Can you send screenshot showing this option?
Thank you
Double click on the camera, then look at the fourth option, as shown
bigcarl5000kg
if the camera position and their dimesions are wrongly set, you can continue to cast spells as you wish and the result will still be the same
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Thank you all,
I picked the forth option and selected all the area that needs to be shown and it works,
thankX.
Technology Administrators
