Hi All,
I create a drawing using a camera
when I select the camera to create the drawing:
on the document manager I see this result:
What should I do.
thank you.
Solved by Tomislav.Golubovic. Go to Solution.
From that screenshot, it doesn't look like anything is inside of the camera's box.
Where is the option to draw inside the camera?
Can you send screenshot showing this option?
Thank you
if the camera position and their dimesions are wrongly set, you can continue to cast spells as you wish and the result will still be the same
Thank you all,
I picked the forth option and selected all the area that needs to be shown and it works,
thankX.
