Drawing file invalid
italo_reboucas6QRUV
italo_reboucas6QRUV
I was working on a model and when tried to save it, the following messagem showed up:
"One or more objects on this drawing could not be saved due to the specified format. The operation was not completed and no file was created."
After that, i could not open the model again and every time that i try to open it, the following message appears:
"Drawing file invalid".
I already tried to restore the file without sucess. I .bak file was created right before this problem but i'm not able to open it because the file doesn't show on the drawing recovery manager.
I opened a 2D drawing of this model and it's working great, even being able to create new dimensions and labels so Advance Steel is still recognizing the information of the model. Can someone help me with this problem. I'm already late on the schedule and if i'm not able to open this model, i'll be in big trouble.
PS: I use Advance Steel in portuguese and translated these messages so maybe they are slightly different for english versions.
Thanks in advance.
Replies (8)
sdonohoedesign
Not sure how to fix your issue, hopefully someone else can help, but I don't think you will be able to save your model unfortunately.
I have always found AS (2018) to be quite stable.  The only tips I can give are to never copy / paste anything into your AS model file, and never upgrade to newer version when you are mid-project.
italo_reboucas6QRUV
Thanks sdonohoedesign.
I also hope someone can help me. I did update to a newer version.
pendean
Community Legend
Community Legend
There are many things you can try https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/how-to-recover-los...
Your daily backup of your files should be of help you recover more useful portions than just the current BAK too.
italo_reboucas6QRUV
Pendean, what you mean by daily backup?
italo_reboucas6QRUV
Is it backup done manually or automatically?
italo_reboucas6QRUV
My model is being updated automatically to the OneDrive but i went to check to see if there was a previous version saved there and found only the crashed version. Does anyone knows if i can find previous versions saved on OneDrive?
italo_reboucas6QRUV
It worked. I recovered a previous version usind OneDrive's Version History.
Thank you for all who helped.
bigcarl5000kg
rename .bak to .dwg and try it
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
