Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Disable Running Dimensions?
3 REPLIES 3
Totec_MW
532 Views, 3 Replies
Can running dimensions be disabled on detail drawings for beams and columns? I can't find a setting for this in Management Tools. Is it somewhere in the drawing processes or drawing styles? I still find the drawing styles dialogue very overwhelming.
Many thanks.
3 REPLIES 3
acbsdesign
in reply to: Totec_MW
I will try to sneak and earn a solution for myself :), Advance Steel Dwg styles are shown, you will have to uncheck in "User" dwg styles :
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
acbsdesign
in reply to: acbsdesign
@Totec_MW
 Sorry,
I thought you are asking about RD symbol, end of a long and rough day here.
You will have to either modify the dimension chain from Linear Ordinate to show Linear Relative, or to delete the dimension request. Below is an example of items dimensioned in Beam dwg style. For column-One side will be "Top", one side will be "Bottom", as if Beam is rotated to be plumb.
Totec_MW
Thank you for the guidance.
Now I just need to work out which dimension requests are being used in my prototypes, but at least I now know what to look for. Thanks again.
