Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Dimension Styles
4 REPLIES 4
337 Views, 4 Replies
Dimension Styles
How can I change dimension styles in drawing styiles of Advanced Steel?
4 REPLIES 4
acbsdesign
We cannot change dimension styles in DSM. We can only change dimensions to be ordinate, relative, etc in DSM.
Dimension styles can be modified in prototypes, in each prototype, and the fastest way would be after modifying in one prototype, if use ADC (type ADC)-select the modified prototype, select dim styles, and Add to other prototypes:
Have a great day.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
in reply to: acbsdesign
thanks for your reply
so, I can’t print in a different thickness or color the dimension lines and those of the element contour?
Julio_Soto
You can change the color of your dimensions in the dimension style manager (make sure to use AS dimension style manager). Then just make sure your pen settings are set up for the color you want to change.
Also, using object lineweight won't do anything unless your pen settings are setup to use them that way.
acbsdesign
It is probably the Plot Syle.
I am using Monochrome.ctb, with predefined line weights per color:
I think the default plot style is Advancesteel_monochrome.ctb
Color 143 (contour lines) -I have the set-up at 0.40, but some prefer it at 0.3-0.35.
