missing midrail on handrail for corner turn
any idea how I can get the mid handrail to appear? I've attached an image for reference.
johnjmbennett
Looking at that , you need a post in that segment to get the corner piece to appear, would be my guess.
I think you are using a loop end , so I think it may struggle with that.
from you other posts today, I guess you don’t have anything to support the post.
you may have to add it in manually, just copy the top rail , trim it back and add in a weld and mitre etc.  Oh change the model role.
John Bennett
Thanks John,
yes the the end loop is suppose to turn 90 degrees and extend. I had to change the connection of the small piece of channel to a weld to the beam so I had room to add a clip angle handrail post to it, I changed a few things in the model role and it seems to be working now
