Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Detailing Column or Beam with Studs?
2 REPLIES 2
Kirk_bailey
358 Views, 2 Replies
How are you guys drawing columns or beams with studs attached?
I'm doing main part Beams and I'm trying to find a simpler way to draw my beams with studs attached.
AS studs on column.pngMy main issue is trying to fit the detail on a drawing.
2 REPLIES 2
Advance Steel won't cheat the drawings. I mean due to object presence in this case the studs, Advance Steel won't cut much from your drawings. By using Drawing Styles, you might achieve something closer to your expectations. You can also change the clipping value of your drawings using very small value for clipping option 1. and 2. and in last resort you can change the scale.
Thanks!
