Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Detail not registered
2 REPLIES 2
2063 Views, 2 Replies
I've created a section and added dimensions.
I now want to make the view larger, but after I select the larger scale and selct OK, this error appears.
Can anyone help?
Thanks.
Can anyone help?
Thanks.
2 REPLIES 2
Sebastian_Eiche
Sebastian_Eiche
Close the detail, open the model DWG, output tab right button from the document manager 'registrate documents'. After this, you had to choose the detail you want and click ok. Open the document manager, update the detail, then open the detail. Now all should work fine
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
in reply to: Sebastian_Eiche
Great! Thanks for your help!
