Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
CX
1 REPLY 1
jdk5225g
138 Views, 1 Reply
CX
Can someone explain what CX means? In learning model roles I see (example) 1/8 = CX. I don't get it.
JK
1 REPLY 1
johnjmbennett
in reply to: jdk5225g
Typically CX is an abbreviation for clipping in the X direction of the drawing,  deployed to removed unused sections of the beam/assembly element to allow for larger scaled view on the drawing.
1/8 “  = 1 “ CX.   Typical associated with the clipping rule for X direction clip.
it can be built into the style and then inturn into a drawing process, I expect that is where you are seeing the naming being used to link the clipping to a style and then a process to generate an assembly or part etc.
https://graitec.com/uk/resources/technical-support/documentation/technical-faqs/faq-2082-why-is-it-i...
John Bennett
