Typically CX is an abbreviation for clipping in the X direction of the drawing, deployed to removed unused sections of the beam/assembly element to allow for larger scaled view on the drawing.
1/8 “ = 1 “ CX. Typical associated with the clipping rule for X direction clip.
it can be built into the style and then inturn into a drawing process, I expect that is where you are seeing the naming being used to link the clipping to a style and then a process to generate an assembly or part etc.
https://graitec.com/uk/resources/technical-support/documentation/technical-faqs/faq-2082-why-is-it-i...
John Bennett
