Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Dear Colleagues,
I have a custom BOM for assembly layout which use as project template as pic 1 show. Then the result as shown in pic 2, as highlighted red box was take from bended plate which welded with baseplate (red circle) which baseplate already become main part, can i exclude the the highlighted box from the table and the result is include the mainpart item only.
Pic 1 :
Pic 2:
Solved by Sebastian_Eiche. Go to Solution.
The list are based on filter search, so therefore you change this list. But be carefull, if you really want to have it everytime. I would maybe create a copy and name it like you want:
next step:
if you don't want to have any folded plate, then you could uncheck the objects:
if it's not clear, then maybe another properties had to be used and set in the model.
For example: include all the object, but not the objects with the Userattribute 2 = NOT in LIST
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Dear Sebastian,
Thanks, it works by using user attribute method. Have a nice day.
