Is there a possibility of modeling a beam that is curved in space (around its axial axis and in the x and y directions) of course with the possibility of setting all parameters.
(see attachemnt)
Solved by Sebastian_Eiche. Go to Solution.
Solved by ArjunGaba. Go to Solution.
@tonilipovac Their is 2 options of doing this
1. You have to draw two different curve beam in x & y than merge it.
2. You need to draw a curve poly line as you want in 3d model than create beam from polybeam and selecting line will works....
....I do not understand,. you mean that I have to rotate the profile every, eg 0.2 m to meet the required shape or there is a possibility to create the required shape via a polyline. Because when I create the required shape from polyline, it is impossible to create a profile from it.
@tonilipovac I mean creat curved beam as you do but do in two parts one in from top view and one from front view please keep in mind system line should be align . Yes you can create any shape using polyline just click beam from polyline if you are crating a curve line mean spline please create spline into polyline by than select poly line
as @ArjunGaba wrote: you could merge two curves to create one polyline or you're able to create a polyline with the settings you want.
If you have a polyline you could use the command: beam on polyline:
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Thanks for your help..but here is an example of what I want.
Attached are polylines in As format dwg.., for example, precisely defined points from which I want to make a steel profile.
you attach dwg with spline--> this is not a polyline.
The result in my pic is because your spline was a bit to small, but this is the way you had to go.
Sebastian Eiche
