Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
curved beam compas mark
6 REPLIES 6
sapch
296 Views, 6 Replies
Why can't  curved beam's  compass mark show?
But the same set of straight beams will display correctly.
6 REPLIES 6
ArjunGaba
in reply to: sapch
@sapch  Normal vector is always changing in curved beam but at straight beam it remains same..As  compass direction changes at when you move on curved beam but in case of Straight line it remain same....
sapch
in reply to: ArjunGaba
Thank you very much for your reply. In 3D View, the curved beam cannot display the compass mark?
ArjunGaba
in reply to: sapch
@sapch  Same issue it will not show. as i stated above..
sapch
Thank you for your answer"Tekla" can be used to indicate the curvature of the beam. Did I use it incorrectly?See the results of Tekla:33.png333.png
ArjunGaba
in reply to: sapch
@sapch  the symbol you are showing is the starting point of member when you modeled it... It is not the  compass mark...
sapch
So how do you get this sign of the arc beam to show up on the 3D view?
Technology Administrators
